Test.
08-02-2018 08:38 PM - edited 01-05-2022 05:16 AM
08-02-2018 08:45 PM
@id909090 If the original SIM is undamaged try simply turning off Suspend Service. This assumes you only Suspended Service.
08-02-2018 08:41 PM
@id909090, unfortunately I do not think you will be able to restore a burned SIM card. You have deactivated your current SIM card. SIM cards are use once only. Your only recourse is to get a new SIM card and apply it to your account.
08-02-2018 08:40 PM
@id909090, You will need to get in touch with the moderator team via private message and see if they can re-activate a SIM that you reported lost/stolen. I am not sure if they can. You might need to get a new SIM.
Click here to send the moderator team a private message. Their hours are: Mon-Fri 9AM-9PM(EST) & Sat/Sun 9AM-7:30PM(EST)
You can find information regarding the moderator team by following this link.
