03-31-2023 07:14 AM
04-03-2023 09:26 AM
04-03-2023 08:52 AM
Just to say thank you to the person that helped me...you seem to be Way. Way more experienced than what they ate hiring to click a button.
Hope you get apreciated.
03-31-2023 07:58 AM
@Lau2 Unable to login My Account?
First try to use the Reset Password link there on the login page (or direct link: https://myaccount.publicmobile.ca/en/forgot-password) enter any possible email addresses you could have used and see if it works
if not, PM support will be your friend then, please open ticket with them
1. Open ticket with Chatbot for faster response (2-48 hours), using direct link: https://publicmobile.ca/chatbot.
Start by typing "Forgot Login Information", then click "Contact Us",, then click "Click here to submit a ticket ↗"
2. if you have problem with Chatbot: Private message CS Agent at:
