Talk Time Outgoing Calls
Koombassi
I have 100 minutes Canada wide talk time. I'm assuming that's for outgoing calls. For incoming calls, is the talk time unlimited?
Thank you Community.
2 REPLIES 2
Koombassi
@computergeek541
I joined PM in July, so I'm guessing on the the newer version you described. Thanks @computergeek541 @for the clarification and solution.
This depends on the plan that you have. There was a previous version of the $15 plan that did not include unlimited incoming calls.  However, most people are on the version of the $15 plan that does include unlimited incoming calls, which is the same version that is currently offered to customers.
