Surfing the Web Internationally
karias16
If I am from Canada, and go to the states, I understand I do not get charged for texts, but would there be an upcharge for surfing the web?
7 REPLIES 7
Good to know... thanks @mimmo Robot Happy
@mimmo wrote:
You will only get incoming texts
 Otherwise as mentioned no service unless you buy the USA add-ons
Is that true @mimmo that you will only receive incoming texts but can't send them when in the US? First I've heard of that...
will13am
@karias16, any usage while in the US will require the purchase of an add-on.  Prepaid format requires features be purchased before they are available for use.  You don't pay after using a feature.
mimmo
popping
PJC
Public Mobile is a prepaid service, you will not get charged anything extra because you will not have access to the web without first purchasing the add-on.
