09-06-2020 12:31 AM - edited 01-05-2022 01:06 PM
I just activated a new sim and it worked. After few minutes, it is showing not registered on network. Now I can't call or send sms. Please somebody help
09-06-2020 10:06 AM
Thank you so much. That was exactly what I did. how I started with SIMon which led me to this level. However, the problem is not fixed yet.
09-06-2020 07:44 AM
@isaacowolabi tour sim probably didn't provision properly. Contact the moderators and ask them to fix it for you. There are 2 ways to contact the Moderator Team:
Once connected to Simon, you will be asked to log in again with your community user name and password. Please do, this allows you to continue and send your message.
- Keep an eye on the envelope top right of your screen. The mods answer will show up there. When it does, you will be asked to verify your self service account, with your password and login. Doing so allows the process to continue. Stay safe.
09-06-2020 01:57 AM
It doesn't work either
09-06-2020 01:56 AM
09-06-2020 01:39 AM
Device is Samsung Galaxy S10
09-06-2020 01:38 AM - edited 09-07-2020 03:27 PM
@isaacowolabi hi what's the make and model of the device? reset your network settings
1. Open Settings>General Management>Reset
2. Tap Reset Network Settings>Tap Reset Settings
If prompted enter your pin, passcode
3. Tap Reset Settings 1 more time to confirm
4. Restart
remove your sim and try it in another device
09-06-2020 01:36 AM
Yes "LTE/WCDMA/GSM" is selected. other available network is "WCDMA/GSM" and :GSM only"
09-06-2020 01:25 AM
@isaacowolabi wrote:I think it's network issue. I tried again searching manually, it discovered public mobile. I selected public mobile, but after long attempt to register on public mobile, it came out that it could not be registered on public mobile. It shows selected network (public mobile) not available. However, I have been using public mobile at the same location before now
Is the phone paid for?
Can you change the network type? ie. LTE/4G/UMTS/WCDMA/HSDPA/3G.
09-06-2020 01:23 AM
@isaacowolabi Try the sim in another phone if it works then it's a phone issue. If it still doesn't work then there is an account provisional issue. You will need to submit a ticket to PM for help.
09-06-2020 01:18 AM
09-06-2020 01:12 AM
@isaacowolabi wrote:Yes it's not detecting network, so it can neither connect automatically or manually. The phone is clean, I checked with IMEI number. Infact, I bought the phone new from Telus before I ported to public mobile.
Not detecting in manual list could mean the phone is broken, or LTE and 3g are disabled. Public doesn't have a 2g network.The network could be down, or network is weak there.
09-06-2020 01:09 AM
09-06-2020 01:05 AM
@isaacowolabi wrote:Yes, it worked means it was connected to the network. I even made a call. Now, it's not detecting network. I have shut down the phone, even removed the sim card, reinserted sim again and powered on the phone yet it's not working.
Not dectecting or not connecting? Try searching manually and see if Public Mobile is in the list. If It's not, it could be a network problem. Unlikely to have happened right after activating, but if you check your IMEI, is it it listed as clean? Go to devicecheck.ca to look.
09-06-2020 01:00 AM
09-06-2020 12:42 AM
@isaacowolabi wrote:I just activated a new sim and it worked. After few minutes, it is showing not registered on network. Now I can't call or send sms. Please somebody help
Does "it worked" mean it connected to the network but now not? Try restarting your phone. Also set network selection to automatic.
