Subscriptions
messenabout
I tried to unsubscribe from a discussion and this is what I got:
Doesn't sound right to me!
messenabout
@HALIMACS @BKNS27  @will13am
Yes it still shows my email address even after refreshing. The only thing is there's a check mark that says do not send me any Community emails. That may not be exactly what I want but I am receiving far more than I need to. I'd rather change that individually however. Anyway when I went to save it with the do not send me the emails check mark it wouldn't let me unless I put in a new email address and confirm it so I just backed out of there. We'll see how it goes. Thank you guys for your immediate attention.
HALIMACS
@messenabout
Tap your  HALIMACS_0-1670120331002.jpeg  avatar upper right, then go down to My Settings.
Does your Community e-mail address appear there?   If so, I suspect all is fine.
@messenabout
That doesn’t sound right if you didn’t request to be removed from this Community.
Either that this might be a mistake or something.
Reach out to a CS_Agent to ask why.
will13am
@messenabout , did you use the my subscription tab to uncheck stuff that you had subscribed to?  If you did that then all is good.
