01-26-2026
10:44 PM
02-22-2026
06:16 PM
computergeek541
I am on the step 6 of 6 and I’m only receiving errors. Tried repeating step 6 but I’m only getting the same error.
01-26-2026 10:49 PM
hi @Jomps
try reboot the phone and login to app again and see if you can complete the subscription
and if you are activating eSIM, can you double check if the PM eSIM is already showing up on your Sim Manager or Settings-> Ceulluar?
if yes, then you need to manually enable it
if not, ask PM support agent to help, you can submit ticket by direct message:
