01-26-2026 10:06 PM
Cannot transfer my number and am getting error message Subscription not activated
01-26-2026 10:07 PM
hi @Lilyhche
try reboot the phone and login to app again and see if you can complete the subscription
and if you are activating eSIM, can you double check if the PM eSIM is already showing up on your Sim Manager or Settings-> Ceulluar?
if yes, then you need to manually enable it
if not, ask PM support agent to help, you can submit ticket by direct message:
01-26-2026 10:06 PM
check with PM.
Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here:
