Subscription not activated
Gen007
Hello,
I am having the same issue as a few other people.  When I try to activate my subscription via the app, step 6 of 6 returned the message ‘Subscription not activated.’ And to contact support.
Gen007
App now says under maintainance when trying to log inl
Gen007
I am trying to activate a physical SIM card with a new phone number and port an existing number upon successful activating.  I tried logging out and back in the app, no luck.
hi @Gen007
try reboot the phone and login to app again and see if you can complete the subscription
and if you are activating eSIM, can you double check if the PM  eSIM is already showing up on your Sim Manager or Settings-> Cellular?
if yes, then you need to manually enable it and set it as Primary (please also remove old carrier sim card and disable old carrier esim)
but if you still cannot complete subscription or sim not there, ask PM support agent to help, you can submit  ticket by direct message:
