Subscription changes
Chang2
Hello,
My subscription is $34 and now I would like to change to $20 one but I can't. Minimum subscription I can change is $29. If I change to $20 then I would like to, otherwise I will cancel my subscription. Would you please let me know I can change to $20 one?
Thanks,
Chang2
Thank you! I will try.
Dunkman
@Chang2
Customer service agents usually will not downgrade plans for existing customers, but you can try.  Looks like PM is leaning towards personalized plan offers for existing customers.  Each existing customers may have different plan offers.  Unfortunately, it looks like most of the offers are likely more expensive than existing plans that the customer presently have.
EB0
@Chang2
Unfortunately, $20 plan is available only to new activations, if you don’t care about number, you may sign in as a new account and get it
Also, you can try to contact support to see if they can give $20 plan to you before canceling or porting to another provider
to contact support, send a message to the CS Agent through the following link
