Submit ticket
Chloe05
Having trouble submitting a ticket to get my number transferred from Kodoo to now public mobile any help would
be awesome
@Chloe05
What have you done so far?
You need to leave the Koodo SIM in your phone and reply to the text with YES confirming you are porting over to PM. You have 90 minutes to reply or porting will be aborted.
What step are you at?
be awesome
Since the ticketing in the chatbot ins't working for you, please send a private message to CS_Agent using this link: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
@Chloe05   Ways to contact Public Mobile Customer Support (CSA) to submit a ticket below:
1-Normally Faster - use this link to: Get Help With Public Mobile Chatbot], also found in various places in Public webpages, OR
2-go to your envelope at the top right of your Community Account which is where your Inbox and Sent messages are. Select the orange/peach color box with the pencil inside it to start a new message. Type CS_Agent in the SEND TO box. This will create a private message to Public Mobile Customer Support (link is provided in #3 below as well).
3 -Use this link (same as #2)  Private Message to Public Mobile Customer Support Agents (CSA)
