Student plan
cannonman55
So just to be clear after reading I can switch to the student plan (20 gig 4g 55.00 per month) and keep my old rewards program cause I didn't switch to the new rewards program
Timer
@cannonman55
when you activated have used this 2GB free data promo code: 2GBBONUS then you will losing when you change plan, for other promo or rewards they will keep it as is. and keep your old rewards program it's better.
Tips: use browser from computer,and clear cache and cookies and use one page inPrivate mode,
To Login Page
and go to Plan & Add-ons, and scroll the plans using the down and up arrows on the far right. select the plan you want, and select ‘Change plan now’ then you pay full price plan, or ‘Change plan on renewal date’..to you not losing any money..
@kaytus- Anybody can change to the plan. The 3x points promo bit is for new activations only.
@kaytus
That's not correct. The plan is for all customers new and existing.
kaytus
Sorry, Maybe I misunderstood.
This plan is only for a new activation.
@cannonman55   Yes you are correct
Plan change would NOT affect rewards system
