12-06-2016 06:01 PM - edited 01-05-2022 01:12 AM
I signed in with PM back on Nov 18 & 19 (2 numbers). Till today, both my numbers have not been ported. The message I received is as follows:
Your Old service provider rejected your transfer request. Common mistakes:
-Account number does not match Old Service Provider Records
-Equipment Serial Number does not match Old Service Provider Records
-Security PIN doesn't match Old Service Provider Records
-Alternate Contact Number Format (should be 10-digits, no spaces, no dashes)
-Did not check the "I am authorized ..." checkbox
Please review and correct your entries, and click "Submit"
However, PM system is not allowing me to re-enter the above information, when I enter my old number and click on "Check Eligibility", the following message appears:
"We are experiencing difficulties processing this request. Please contact Public Mobile for additional assistance."
I have been patently waiting, but it's been over 3 weeks!!!!!
I have the old service provider Account# available. Can someone please contact me.
Please help!!!!!
12-06-2016 07:07 PM
Tagging them will make them aware of this forum post as posted above. If you send them a private message (PM) it will enter into a queue to be addressed by the mod team. You can PM one mod and it will enter a message pool to be addressed by any of the mods.
The information you need regarding PM and some names of mods can be found here:
12-06-2016 06:59 PM - edited 12-06-2016 06:59 PM
hey @Olguita if you type @, a dropdown will show up and u can pick from users that are in this thread... or just keep typing and it will suggest user from full user base.
of u can use the 'add tag' button below
12-06-2016 06:57 PM
Thanks!,
But... how do I tag them?... sorry, new to all this.
12-06-2016 06:28 PM
Have you tried PMing the mods to see if their technical team can assist you?
Tagging @Shazia_K and the mod team to try and help you out!
Hope you get a resolution to this sooner than later.
