Spam calls
Monikaj98
I’m getting spam called by numbers from North Dakota I’m located in Canada I block them everytime but they always go to voicemail and end up filling my voicemail they’re none stop up to ten times a day from many new numbers idk what to do I put my number on the do not call list for Canada but I can’t put it on the United States one also when I’ve picked up there is nothing on the other end same with all the voicemails is just nothing I’m so frustrated I don’t want to have to change my number cause of the hassle
Phil_Adelphus
@Monikaj98   There are Android apps that supposedly block spam calls but I don't know which is worth trying and you need to be careful what you download, but you could try checking out reviews via a search engine.  I've found that Apple's Live Voicemail is a game changer for my iPhone since it enables stopping the calls before they get to Public Mobile voicemail although I do have to hit the iPhone voicemail symbol to intercept the unknown numbers.   This means no having to log in to PM voicemail every time a spammer leaves a message. You need an iPhone that can run ios 17 for that. I'm finding the majority of spam calls these days seem to come from the USA.
OlivierR
You can check in the settings on your calling app some phone have a built in spam filter you can enable it or make more strict if you have one
Hollister
@Monikaj98
There is not much you can do but keep on blocking those numbers.
