Slow data on new activation
02-27-2024
08:00 PM
02-28-2024
01:04 AM
computergeek541
Hi,
anyone having slow internet i just activated the $34 plan 5G 50 GB CAN-USA plan internet is extremely slow speed test showing 0.41 mbs sometimes i can get 1.4 mbps i moved my sim to another phone to rule out my android with same results.
Service
02-27-2024 09:07 PM
thank you, it was same result outside of the house as well. I have fido on my other phone which is working as expected.
i will wait for feed back from CS
02-27-2024 09:00 PM - edited 02-27-2024 09:00 PM
And ... was it just in your house @Joester801
I presume other people with other providers are getting higher speeds in the same vicinity as where you are testing speeds.
If still the same slow speeds, reach out to customer support to have them try an account reprovision. You should be getting higher speeds.
To contact a Customer Support Agent, send a private message to them by clicking here. You’ll need to be logged into your Community account for the link to work.
Watch for their response in your Community private mailbox which will be indicated by a number on the small envelope icon to the left of your Community avatar, or tap your Avatar down in Messages.
02-27-2024 08:13 PM
I did go outside and go for a ride outside for a bit to see if it was just in my house.
02-27-2024 08:10 PM
To be certain, turn off your Wi-Fi switch, go outside, and try the test again.
Be advised that these speed tests can consume as much as 200 MB of data.
02-27-2024 08:10 PM
I just switched on pixel 4xl LTE - speedtest is 170mb
