Sim unlock code
passiveegg
I am buying an locked TMobile phone and I wanted to know if public mobile will give me a sim unlock code. Any help is appreciated.
@ddrodge wrote:
Public mobile does not supply the unlock code.   You have to contact the original cell provider and give them the IMEI# and they will give you the unlock code.   It is free in Canada I am not sure if it costs anything in the US.
This question was asked and answered more than a year ago.  i'm sure that you just didn't notice that.
ddrodge
mimmo
I have unlocked about 5 phones. I usually just find the cheapest. You need to give them IMEI of your phone. As the unlock code is unique to each phone
@passiveeggI looked on ebay and seems T-mobile v10 not realy itsed there. did some searching oline and could not find much elese they were very costly.
i think you should NOT buy that phone. https://forum.xda-developers.com/tmobile-lg-v10/help/sim-unlock-t-mobile-lg-v10-t3279171
can try this site but you need the imei http://www.cellunlocker.net/lg-unlock.php
passiveegg
Thanks so much, I was just wondering if you knew which code is good because I have the LG V10 FROM TMOBILE. If you can find it, please message it to me. It will be greatly appreciated @mimmo
mimmo
ebay is your friend if you are using android.  Most android unloc codes are <$5
iphone not sure wat to suggest.
