04-17-2020 04:41 PM - edited 01-05-2022 10:24 AM
I ordered a SIM card for my iPhone 7. I received the wrong size SIM card. How do I return the wrong Sim card and get the correct SIM card sent to me.
04-17-2020 05:11 PM
@MariaGuilbault Thats the beauty of triple punch SIM's. You dont have to worry about sizes
04-17-2020 05:09 PM
@MariaGuilbault wrote:I ordered a SIM card for my iPhone 7. I received the wrong size SIM card. How do I return the wrong Sim card and get the correct SIM card sent to me.
@MariaGuilbault No need to return the card. Public sim cards are tri-punch just punch out the size that you need.
04-17-2020 05:02 PM
Maria the sim card punch out. it is made that way so it can be used with universal phones.
Public Mobile provides a triple punch SIM card that will fit into almost any phone you choose. Determine your phone’s SIM card size by checking the SIM tray, and remove the parts of the SIM card that you don’t need. When purchasing a SIM card, you can choose to do so online or at one of our retail partners. For a list of retail partners, see here under Step 2.If you are purchasing a SIM card online, here is what you should know:
To purchase your Public Mobile SIM card now, click here. We recommend you use the same email address for purchasing your SIM card that you will use for activating your SIM card.
04-17-2020 04:49 PM - edited 04-17-2020 04:51 PM
Be careful when you take the nano card( from the 3 in one) that you don't damage they are a bit fragile,i've done that,sometimes they are a bit stuck together.
04-17-2020 04:45 PM - edited 04-17-2020 04:48 PM
@iliketotalk punch it down.
Here's 3 articles on activation and porting and the Refer a friend reward if applicable
1.How to activate https://www.publicmobile.ca/en/bc/get-help/articles/activation-account-set-up
2.How to port https://www.publicmobile.ca/en/bc/get-help/articles/choose-your-phone-number
3. Refer a friend https://www.publicmobile.ca/en/on/get-help/articles/the-refer-a-friend-reward
Stay safe.
04-17-2020 04:42 PM - edited 04-17-2020 04:44 PM
@MariaGuilbault hi it is a triple punch sim it comes apart to your size I also had a iphone 7 it will fit😊
04-17-2020 04:41 PM - edited 04-17-2020 04:43 PM
By the way the sim card has punch outs to fit all phones.
If you need to contact a moderator then this is how, but you should not need to.
Please use the chatbot SIMon to help you solve your issue. If SIMon cannot solve your issue then you have the option to contact a moderator.
Step 1: Choose the ? button at the right bottom corner of this page or choose “Get Help” at the top of the page and then choose the “Chat with SIMon” button.
Step 2: Tell SIMon what the issue is and see if he can find a solution for you.
Step 3: If Simon cannot find a solution then type in “moderator” to connect to a Public Mobile customer service representative.
Step 4: Simon will present you with two choices. Choose “Account-specific question”
Step 5 Then choose “No, I want a human”
Step 6 Create your ticket
Check the sent folder to make sure your ticket was sent (envelope icon, top right) and the inbox for a reply from the moderators.
“To ensure the safety of our team members during the COVID-19 pandemic, our Moderator team is working at reduced levels. During this time, you may experience longer than normal wait times when contacting our Moderator team for help.”
Moderators are available:
Monday to Friday from 8 AM to midnight Eastern time.
Saturday and Sunday from 8 AM to 10 PM Eastern time
