Sim card rebate
Options
08-22-2016 10:52 PM - edited 01-04-2022 03:05 PM
Hi.
I need to get the courier rebate for the sim card i just ordered but i cant seem to find the email that has my order #.
Is there any other way that i can this refund without the order #?
Thanks.
Thanks.
Labels:
Service
1 REPLY 1
Options
08-22-2016 11:03 PM
You have to activate that sim first in order to get refund.
Check in spam folder or simply try searching with keywords like sim or order.
They might be able to look it up from the PM ph number you ll give if you can't find the order number.
