Sim card network pin
01-20-2018 10:23 AM - edited 01-05-2022 03:56 AM
I bought a l g4 off someone and it keeps asking me for a network sim pin number, how do I find it ? I really would like to use my new phone
Service
01-20-2018 04:34 PM
Network pin or NCK is an unlock code that is used to make it so that the phone will accept sim cards from other carriers than the original. I would not suggest guessing at such codes. You will not be able to correctly guess an 8 or 16 digit unlock code. In addition, if you guess incorrectly more than a few times, your phone will be permanently locked to the old provider.
01-20-2018 03:55 PM
Yeah I agree, it sounds like the phone is locked to another provider.
01-20-2018 11:09 AM
@Praza1Are you sure the phone is unlocked?
can you to ask a friend to pop in a roger/fido or bell/virgin sim? even stop by a kiosk and ask?
01-20-2018 11:09 AM
Try 1234. If not working, contact our moderators for help.
