Sim card compatability
IsabellaPinel
Im just looking to find out if my sim card would be compatible for a new phone. Im looking into the google pixel 9 and i cant find the answer on the site
17
1 REPLY 1
Yes @IsabellaPinel the same PM AIM card will work across different phone.  Just I'm case you see your current sim card is bigger in size, there is actually pre-cut frame you can remove to make it small, make it nano size
