Sim/Credit Card Activation keeps failing.
reppact
New customer. New Sim. Trying to activate the sim, choose a plan and start using the service. But the system keeps claiming that the CC/billing info I've entered correctly is not working/valid. Even on TWO different browsers the same result.
I don't need to check my bank as I entered the EXACT billing info they have on file.
Seriously Public Mobile, do you want me as a customer?
Jackhyf63
I think you need sent Pm to Mods ,they will take care of it. In your private message include phone number, account number, pin and sim card number.
cavemantoronto
@reppact was your credit card bill in your online credit card balance?
You could activate by purchasing payment vouchers from a store or recharge.com.
Don't use the unit # field and try either of no space in the postal code or drop the last #.
NDesai
@reppact Try using incognito/private browsing mode and see if that resolves your issue.
