05-05-2026 11:54 AM
I ordered sim card on April 6, 2026. I received a confirmation email that order has been processed. However, I haven't received the sim card yet.
05-05-2026 11:59 AM
hi @Susuay9
Sim card delivery can be 3 days to 3 weeks here
But best to ask PM support agent for status update, you can submit by direct message:
Better to ask if you can pickup another one from a nearby Telus or Koodo store instead of wait longer to have them resend a new one
05-05-2026 11:57 AM
it should come within 3 weeks.
Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here:
