07-08-2021 11:35 AM - edited 01-06-2022 02:44 AM
Hi
I just paid $15 to activate my Sim Card for the next month.
But it is not working now!
Please help me have it fixed as soon as possible.
Best,
07-08-2021 01:19 PM
Thank you. It is working now.
Best,
07-08-2021 12:35 PM
@SeyedZia Yes, let us know if it is working from here.
or if not, just provide us the information and we can try to help
07-08-2021 12:32 PM
Thank you.
It is OK.
Best
07-08-2021 12:15 PM - edited 07-08-2021 12:16 PM
@SeyedZia wrote:Hi
Best,
Hello @SeyedZia ,
Is there a Reactivate or Resume button on your Self Serve account you can select?
If so, select that. Then reboot your phone.
If that does not work, try topping up your account with $1, this sometimes triggers the account to reactivate.
If you account status shows ACTIVE already, then try:
07-08-2021 11:40 AM
@SeyedZia did you check if PM charged your credit card?
did you pick a new number or you request to port number from your old provider?
when did you activate the line? did you reboot your phone? Try to reboot once more. Then try to make an outgoing call.
Let us know how it goes
