03-30-2019 09:29 PM - edited 01-05-2022 04:03 AM
Hey all,
I'm trying to switch my dad from Virgin to PM. We opened the account no problem and clicked transfer number over. Everything looked good but now when I put the PM SIM card into his phone it says the SIM card is locked. Anyone have any ideas?
Thanks,
Kovie
Joining Public
03-31-2019 09:33 AM
Phone was locked. Thanks all 🙂
03-30-2019 11:43 PM
@Kovalchuk wrote:Hey all,
Thanks,
Kovie
You can't use it until getting the unlock code from Virgin. The unlock code will be free. They sometime give hard time if you are not a customer any more, but if you are still customer, they have no choice.
03-30-2019 11:21 PM
Thanks,
Kovie
@Kovalchuk Hi Kovie, it could be the phone locked by Virgin. You have to ask Virgin to unlock it.
03-30-2019 10:04 PM
From Wikipedia:
A SIM lock, simlock, network lock, carrier lock or (master) subsidy lock is a technical restriction built into GSM and CDMA[1] mobile phones by mobile phone manufacturers for use by service providers to restrict the use of these phones to specific countries and/or networks. This is in contrast to a phone (retrospectively called SIM-free or unlocked) that does not impose any SIM restrictions.
https://en.wikipedia.org/wiki/SIM_lock
In Laymen's term, the phone is locked to only use certain cellphone providers, in this case Virgin Mobile. You would need to contact them to unlock your device:
https://www.virginmobile.ca/en/support/faq.html?q=unlocking-your-phone
Good luck.
03-30-2019 09:51 PM
@Kovalchuk wrote:That was my initial thinking. I thought only SIM cards could get locked, not entire phones
Yes your phone can be locked from the last company and if it is the case you need to contact them to unlock your phone..and it's free..
03-30-2019 09:51 PM - edited 03-30-2019 09:54 PM
@KovalchukPhones get locked too. You will have to contact Virgin for the unlock code.
03-30-2019 09:49 PM
03-30-2019 09:47 PM
Thanks,
Kovie
Is his phone unlocked ?
