Signal
06-15-2019 12:10 PM - edited 01-05-2022 08:04 AM
06-15-2019 01:15 PM
Never had any issues! I go to surrounding communities around Edmonton and had consistently strong signal! 😉
06-15-2019 12:46 PM
Here is a coverage map. https://www.publicmobile.ca/en/bc/coverage. PM uses Telus and Bell towers so there is generally good coverage. If you are in a metropolitan area then the coverage should be good.
06-15-2019 12:13 PM
@sweetrhonz wrote:Is the public mobile has a strong signal out of edmonton?
Scroll to the bottom of this page and click on Coverage Maps. It's Telus. It'll be fine.
06-15-2019 12:13 PM
@sweetrhonzYes the signal should be strong.. however you should verify your location to see how many towers is in your vicinity.
