Setting up old SIM
02-01-2021 02:40 PM - edited 01-05-2022 05:06 PM
In the Account setup, it asks for the 19 digit SIM number. But mine is 20 digits (and will not be accepted). Anyone know why this is? Do I really have to go buy a new SIM?
Joining Public
02-01-2021 05:27 PM
Did you already activated it in the past? Ib that case you would need a new sim
If not, good news is that sims don't expire. If you are certain you have Publicmobile sim and that you are looking at the right number and it's still 20 digits, you could take a picture of it and contact moderators team they should be able to direct you
02-01-2021 04:21 PM
@kb_mv : How should I know. Seems 20 digits is the main standard though. Maybe PM is sending them out now but knowing them, they haven't updated their system for them.
02-01-2021 04:16 PM
@Anonymous wrote:Did a little looking around. So see those zero's in the middle...try dropping one of those.
@Anonymous Where would the OP possibly get a Public Mobile sim card with 20 numbers instead of the standard 19?
02-01-2021 04:11 PM
02-01-2021 03:44 PM
Should be like this....I found in Google Pics....so I doubt if the number is valid!!!
02-01-2021 03:25 PM - edited 02-01-2021 03:27 PM
Look like you need to buy a new SIM if you meant you are tried to re-use a SIM that was previously activated.
Just an FYI, if you need to order new SIM, ordering from PM site would take some time for it to arrive at your door due to courier delay. You might want to order from Amazon Prime for it's 2 days Prime delivery, or via Canadian Cell Supplies or go to a kiosk like Walmart/Loblaws/London Drugs
02-01-2021 03:01 PM
@LauraGranger : If it starts with a zero then maybe drop that zero.
02-01-2021 02:41 PM - edited 02-01-2021 02:42 PM
A previously used SIM will not longer work. Yes you need a new one.
