Setting number of rings before voicemail
Mc9
Hi.
I am trying to extend the number of rings on my phone before voice mail picks up. I have tried using the code **61*+15875884002*11*30 (I am in Alberta) but I get a message saying something to the effect that I don't have Talk and to go on self-serve. Can someone please help me?
Thanks in advance
9 REPLIES 9
RichardKCLing
I figured it out after asking differnent questions with search
RichardKCLing
I keep messing up with the tags.  How do I set the number of rings?  With this string?
I found out my rings are set to 25.  I want 35 if the max is not 30.
**61*+15875884002*11*30  (The 587 is my telephone number?)
Thanks.
@Mary_M @Shazia_K
RichardKCLing
This works.  I'm at 25.  How do I extend it to 30 or more?  Thanks.
I was with Bell.  I keep missing calls at PM.
Greg1
What does dialing *#61# (send) display?
That should tell you what it's currently set to.
Here's all the info you'll need to set a different delay.
http://www.geckobeach.com/cellular/secrets/gsmcodes.php
I would try in increments of 5 seconds to increase it, and I think 30 seconds is max. Mine is set for 25 seconds, that seems to be the default.
mikga
Can anyone tell me how to set this - set the number of ring - 6 rings before it's going voicemail.
Thanks
Mary_M
Retraité / Retired
Retraité / Retired
Hey @Mc9
I understand that you would like to extend the number of rings before going to voicemail.
This is actually something that must be done on your device - if applicable. Depending on the phone, calls go to voicemail after about 4 to 6 rings.
How many times does it ring before your vocemail comes on ?
Mary
** Please do not post private info such as: phone number, account number, pin etc.. This is a public forum. **
Do you have talk on your plan?
If yes, staff member will see if you can extend ringtones.
@Shazia_K @Mary_M
Mc9
Mc9
****Sorry edited above... I didn't mean ringtone but number of rings!
