Set up session timed out now saying Invalid SIM
88srb
My Session Timed out when I went to set up my Payment information.
It is now saying invalid SIM
Any assitance would be appreciated.
88srb
Thanks everyone.
Set up and activated with Chrome in Incognito.
GR
Sometimes the website times out but the credit card is charged and the activation work!
88srb
Thanks, hopefully it works next time.
GR
@88srb now you have to wait 1 hour for the system to release your sim number so you can try again!  Before you try again you should check your credit card to make sure it was not charged.  If it was charged then try your sim card in your phone to see if it works.
RossN
@88srb  hi after a few attempts you get booted out wait an hour and try again after you reboot your computor try using ingognito mode in chrome it seems to work good
