05-05-2023 09:06 AM
Hi i just changed my phone number
after that I can’t make a call or messages
05-05-2023 09:28 PM
everything seems okay but still not working
05-05-2023 07:52 PM
Hello, I changed my phone number and in profile it is showing my new number. I can't make calls, texts and also, data is not working
05-05-2023 11:31 AM
yes
i did
05-05-2023 10:16 AM - edited 05-05-2023 10:29 AM
05-05-2023 09:57 AM
@ankurr500 , please try turning off your phone, remove your SIM card for 5 minutes then put it back in phone, turn phone on & see if that helps. If it doesn’t reset network settings in your phone, reboot then see if that fixes it. Let me know please.
05-05-2023 09:48 AM
It is showing new number in my profile
05-05-2023 09:47 AM
so you checked as suggested and your number is correct or still old number ?
05-05-2023 09:35 AM
Did everything still not able to call or text
05-05-2023 09:33 AM - edited 05-05-2023 09:38 AM
did you try restarting the phone.
Try cycling Airplane mode ON, then OFF.
When you log in to your PM account on a laptop, look in Profile..then look to see what your phone number is listed as.
added...
05-05-2023 09:22 AM
05-05-2023 09:16 AM
did you change your phone number is the self serve area of your account ?
Try restarting the phone...see if that helps.
