08-08-2018 04:22 PM - edited 01-05-2022 05:19 AM
I just ordered my SIM card. Was wondering if anyone from Newfoundland, Canada has joined up and how transition from telus was
Service
08-09-2018 12:10 PM
If you were happy with your Telus coverage then you'll be happy with Public Mobile coverage. Welcome aboard!!
GC
08-09-2018 11:45 AM
Public Mobile is a Telus-owned brand, and as thus, uses the exaxt sane netwotk. So, there will be no difference when it comes to that if coming as a customer from Telus. The only differences will be on retail prescense, customer service, and in plans and pricing.
08-09-2018 05:35 AM
Thank you. Does your plan have 3G or 4 lte for data?
08-09-2018 05:30 AM
Creston North, on the Burin Peninsula
08-08-2018 07:09 PM
When in doubt, this cell tower site is a good resource.
08-08-2018 05:39 PM
Forgot to address your question about transitioning from Telus. First of all if you were on Telus then your phone will definitely work with Public Mobile, even if it's locked.
When I transferred from Telus, after I ported my number and finished the activation process, everything worked perfectly less than a minute later.
GC
08-08-2018 05:32 PM
I am in Newfoundland and service is absolutely fine for me. As stated above it runs off Telus and your service should be as good as Bell or Telus. What part of Newfoundland are you in?
GC
08-08-2018 04:30 PM
Publicmobile uses the exact same cell towers as telus, service should be exactly the same. As for data, if you get 3G it is slightly slower than LTE, but not noticeable for me. The 3G is actually just throttled LTE rather than true 3G.
08-08-2018 04:28 PM
Telus is stronger out west but they share towers with Bell. If you were fine with Telus then you'll be fine with Public Mobile (PM). Seeing as how PM belongs to Telus.
