Service Quality
01-19-2020 08:56 AM - edited 01-05-2022 09:05 AM
Hi
I am looking for a cheaper cell carrier and I am wondering what the service is like in rural New Brunswick
Joining Public
01-20-2020 12:29 AM - edited 01-20-2020 01:05 AM
@computergeek541 wrote:
@tgenereaux wrote:Hi
I know that it was mentioned that you'll want to check Telus coverage maps. A followup to that: Which city did you wan tto get a phone number for? There are places that Public Mobile service will work but local phone numbers are not offered. While Public Mobile's calling plans are Canada-wide, this coudl be a factor for people trying to call you.
Adding to this: There were a couple of reports from Atlantic Canada that some new Telus towers are only equipped with LTE gear. Since Public Mobile's voice service is running on 3G there might be spots that talk works perfectly fine for Telus or Koodo clients using VoLTE, but PM customers are out of luck for calls.
So, signing up for a trial period before porting your number is recommended.
01-20-2020 12:21 AM - edited 01-20-2020 12:52 AM
I know that it was mentioned that you'll want to check Telus coverage maps. A followup to that: Which city did you want to get a phone number for? There are places that Public Mobile service will work but local phone numbers are not offered. While Public Mobile's calling plans are Canada-wide, this coudl be a factor for people trying to call you.
01-19-2020 01:14 PM
@tgenereaux You can activate a Public Mobile sim card at Walmart on the $15 plan. Most of the time they provide the sim card for free. Just pick a temporary number to test with. If you use a referral code during your activation (need to provide the code to the Rep during activation) you will get another $10 credit and another $2 off if you use AutoPay. Test coverage for the next 30 days and if you are satisfied then you can port in your phone number from your current provider. If you are not happy with PM then just remove your AutoPay via your online selfserve account to discontinue your service with Public Mobile.
01-19-2020 09:20 AM
@Triguy wrote:Here is a Telus coverage map.
https://www.telus.com/en/bc/mobility/network/coverage-map
And here is Rogers if you're more familiar with their coverage.
01-19-2020 09:17 AM
01-19-2020 09:09 AM
@tgenereaux , if you have ever used the brands like Telus, Koodo, Bell, Virgin, Lucky,y are going to have the same coverage. Ask a family or friend if you have not tried them.
01-19-2020 09:03 AM - edited 01-19-2020 09:10 AM
Check here to see PM coverage for your area:
https://www.publicmobile.ca/en/qc/coverage
PM uses the same towers as Telus and Bell. So you have Canada’s largest mobile network for the lowest possible price.
Don't forget the reward benefits: https://www.publicmobile.ca/en/qc/get-help/articles/reward-rules.
Register your credit card to sign-up for AutoPay, you'll get $2 off your renewal evey 30 days.
If decide to sign-up with Public Mobile, don't forgot to enter a referral code when you activate. You will receive $10 credit on your account to be applied towards your first renewal.
