Service. Eversafe
BV63
Eversafe keeps sending 6 digit number to the new number with this phone, but it's not activated.
Radar231
One thing you can do is change it to send the confirmation code via email. There's a link under the code entry boxes that let's you change the code destination.
BV63
It hasn't been activated I think. I called the number and it doesn't ring.
BV63
Thank you!
Sansan
@BV63  if you can't get into your account, use the link below to send a private message to cs agents for further assistance.
hi @BV63
so, is it just eversafe issue or the service not activated?
maybe ask PM support agent to check as well.   You can submit  ticket by direct message:
