01-24-2018 04:14 PM - edited 01-05-2022 03:57 AM
Hello
I'm trying to send a group text using my blackberry keyone, but I keep getting the error
"Message not sent : service not activated on network"
Does anybody know what that means or have a solution to this? Sending a text to a single person works
Thanks
01-24-2018 04:31 PM
@mibs000 wrote:
@NDesai wrote:Group texting is enabled with Public Mobile. Check your texting app settings and see if group texting is enabled.
Thank you for the reply. Do you know where or how I can do so. I have an android os but I can't find any setting regarding text messages
Oh, it's an Android os. Try using Android Messages app. In settings you will see group texting options. See if that works.
01-24-2018 04:30 PM
Found it and it worked !
Thanks
01-24-2018 04:27 PM
01-24-2018 04:22 PM
