Self Service Down?
goatowlpig
Been trying to access self service all day and am just getting a white page, have tried multiple different browsers as well as different devices. Is anyone else getting this same issue?
Link I'm using
https://selfserve.publicmobile.ca/
junjunc
Not having any issues for me. I'm from BC Canada. Everything is working when I log in with Chrome. Have you tried to delete the cookies and caches before another try?
@goatowlpig Mine works fine without clearing cache or using incognito window.
macsal
@goatowlpig alright, so i am also getting the WHITE ONLY screen.
But I cleared my browser and using incognito tab, and it worked again for me.
Keep trying, maybe they are working on something.
macsal
@goatowlpig wrote:
@macsal Incognito doesn't seem to work for me for some reason.
Try clearing your browser's cache then try the incognito mode tab.
goatowlpig
@macsal Incognito doesn't seem to work for me for some reason. It has to be something on their end if I'm not the only one with the issue.
macsal
Hi there,
Yes @goatowlpig , i had the same issue. But then i opened a tab in incognito mode and it worked! Try that.
ADDING info:
You can also use a keyboard shortcut to open an Incognito window:
Windows, Linux, or Chrome OS: Press Ctrl + Shift + n.
Mac: Press ⌘ + Shift + n.
