03-25-2021 04:55 PM - edited 01-06-2022 01:33 AM
Hi I need to send screenshot of a receipt to a moderator. Is there a number to send it to? Not sure how to send it either...lol I did get the pic taken though Thank you
03-25-2021 05:54 PM
I'm happy it helped....yes mine is from a tablet so a little different but it got you there all the same!
03-25-2021 05:41 PM
Hi Thank you ever so much. I was able to follow allow with your visible instructions. Mine was a bit different, but the same. I just hope they get the pic. Thank you again Sherri
03-25-2021 05:28 PM
03-25-2021 05:09 PM
Hi Thank you Everyone! Newbie to cell phone
03-25-2021 05:05 PM
@sherri8 wrote:Hi I need to send screenshot of a receipt to a moderator. Is there a number to send it to? Not sure how to send it either...lol I did get the pic taken though Thank you
Hi @sherri8 what receipt would that be? Did a moderator ask for that particular receipt? If this is so, send the screenshot of the receipt to that moderator.
If you haven't submitted a ticket for the moderators,
Two ways to contact the moderators:
It may take up to 48 hrs (hopefully less) to receive a reply from the moderators. Keep checking the envelope icon on top right for a number to pop up. That would be the moderator’s reply.
If you have any further questions, just ask
RosieR
03-25-2021 05:04 PM
Hi I was speaking with the moderator on desk top computer. I see I needed to be contacting them on my phone. I hope they will see my message to them and write me back. Thank you
03-25-2021 05:02 PM - edited 03-25-2021 05:05 PM
@sherri8 : What receipt? Is this a voucher that didn't work? Did you try both the 611 service and the self-serve? If there were multiple sets of 12 digits, did you use the one called PIN?
The private messaging is very similar to this posting. Use the little camera icon above the text box.
03-25-2021 05:00 PM
Hi @sherri8 Were you chatting with a moderator through Private Message? If so, you can reply to them via private message and attach a screen shot. If you have not contacted a moderator yet regarding your situation, you can open a dialogue via the chat button bottom right and follow the prompts to contact a moderator. Once they contact you via private message, then you can reply and send them your screen shot.
03-25-2021 05:00 PM
@sherri8 - Normally, all communication with moderators is initiated using SiMon (clicking on the chatbot icon on lower right). however, if a moderator asked for it, you likely have a message from them in you inbox. You should be able to respond from there.
