03-18-2025 03:50 PM
Hi, does anyone know if Volte will work ? This phone was purchased from Samsung Canada online store.
Thanks
03-18-2025 07:11 PM
@T250cc1 S25 is VoLTE enabled on PM
if you make calls, the call screen would show HD voice. Also, you will see the network stays on 4G or LTE and does not drop to 3G, another indication it is VoLTE
03-18-2025 07:05 PM
Further update, when I insert my public mobile sim ,I noticed under sin card status that my IMS Registration Status indicated my phone is registered whereas on my old phone shows it is not registered and when I make phone calls on the old the H+ icon is showing up on my notification bar indicating that my cal is on the 3G network. Also, I noticed on my S25 ultra there is no icon indicating if my phone call is Volte or HD. I read online that if he phone show it is registered ,then, it is using Volte. Anyone know if this is true? I also tried a Bell sim card and it also display the registered status. So, it safe to say I'm using the Volte network on both phone company.
03-18-2025 03:52 PM
@T250cc1 wrote:Hi, does anyone know if Volte will work ? This phone was purchased from Samsung Canada online store.
It should be fine, but the only absolute way to know is to check while using the Public Mobile service.
