03-24-2020 06:23 PM - edited 01-05-2022 10:04 AM
When I make the switch, can I expect that my device will do an automatic hard factory reset again, like it did when I first put my koodo sim in. Just need to know if I should back up all my data before switching sims ?
Joining Public
03-27-2020 10:28 PM - edited 03-27-2020 11:44 PM
Just coming back to confirm, for anyone with this model anyway, that my phone did in fact not factory reset after the sim swap. I did a backup first to be safe and will keep it, but no reset is official 🙂 of course I can't speak for other models officially, but in case others with this model are looking to switch
Oh and also, my data worked without having to change any settings on my device
One more thing I'm thinking to add, I had a mild heart attack when I got a koodo email stating my service was canceled (not ported)... But not even 2 minutes later got the text from public that I was all set up with the phone number from koodo!
03-25-2020 02:02 AM - edited 03-25-2020 02:03 AM
@Pawprints1986 On my old phone, a Samsung J1 2016, I didn't have to change my APN settings. And everything worked properly. But I did a factory reset before. On my new phone a Umidigi F1 from Amazon I had to set my APN To these below:
03-25-2020 01:23 AM
No. Like I said...I don't think I had to do anything. I also don't recall it resetting. But I hadn't moved the phone here from another provider and would have done a factory reset when I got it and the phone would have had no useful data on it...so I don't remember.
03-25-2020 01:16 AM
Yep, mines on 8 as well but I'm fine with that. Still perfectly supported. But are you meaning that not being on 10 means I'll have to manually change those settings ?
03-25-2020 01:03 AM - edited 03-25-2020 01:04 AM
I bought my phone used from a repair store. The previous owner upgraded it to Android 8.0.0. Apparently it's not 10 eligible.
Settings/Connections/Mobile networks/Access Point Names
I'll just type what is set:
whatever name
APN = sp.mb.com
MMSC = http://aliasredirect.net/proxy/mb/mmsc
MMS proxy = mmscproxy.mobility.ca
MMS Post = 8799
MCC = 302
MNC = 220
APN Type = default,mms,supl (<-hotspotting might need ,dun)
APN Protocol = IPv4
MVNO type = GID
MVNO value = 4D
03-25-2020 12:34 AM
@CannonFodder wrote:
@computergeek541 wrote:
@Pawprints1986 wrote:1 other related question... Once I'm ported over to PM, will I need to change any settings to be able to access data properly ? Any step by step available regarding that process ? Or because I was koodo which is also telus like PM will it remain the same?
Fairly recent phones sold by Telus or Kooodo aren't going to need any changes to the APN settings to use data on the device at Public Mobile.
REALLY!? 😯 I suppose there's something in there relating to "fairly recent phones", because my Galaxy S3, which had APN settings for Koodo still on it, wasn't able to access data on PM 'til I added some APN settings for PM.
It's look like your model was made a few years to early. I know that the 2015 version of the Moto G had Public Mobile settings in there already. I've also tried a few other Telus devices and those didn't need Public Mobile's settings to be entered manually either.
03-25-2020 12:32 AM
@Pawprints1986 wrote:Where can I find the apn settings? Just for reference ?
Meaning on the PM site, not my device. Like the setup instructions
03-25-2020 12:30 AM - edited 03-25-2020 12:31 AM
03-25-2020 12:28 AM
03-25-2020 12:25 AM
No. You'll need to set up the Public Mobile APN settings. It may also just do it on it's own. I also have an S7 and I don't recall having to change anything like that. My older Windows Phone yes.
03-25-2020 12:25 AM - edited 03-25-2020 12:25 AM
03-25-2020 12:20 AM
03-24-2020 11:58 PM
No I didn't log out. It's the unpredictability that is ridiculous.
03-24-2020 11:56 PM
@Anonymous wrote:Frickin' thing. I had it earlier today. Now I don't. Nothing's changed. How ridiculous is that?
Ah, but did you log out between then and now? I have, several times, but it still continues working, but in the past several days, it can be working, and then when I log back in, a few hours later, then it's not working, or vice versa..... 🤔
03-24-2020 11:53 PM
03-24-2020 11:49 PM
@kselmak wrote:Yeah I noticed it after posting:)
Btw did some people get the quote button back? I can't find mine anywhere
I miss that little button
Well, as you can see, it's working fine for me, and has been all day..... for a change. However, I won't be holding my breath expecting it to STILL be working tomorrow, but if it is, I'll be pleasantly surprised.
03-24-2020 11:14 PM - edited 03-24-2020 11:15 PM
03-24-2020 10:26 PM
I will update when I make the switch, just in case for anyone else wondering the same with the same model. But to be safe I can do a full backup first just to be safe, rather be too prepared 🙂
03-24-2020 08:36 PM
Pawprints1986, from reading the document, the listed model SM-g930w (yours is g930w8) will reset the FIRST time a sim card is inserted, but if you put a different sim card in after
it will not.
03-24-2020 08:14 PM
I should have said, I didn't get my phone from koodo, I bought it from best buy online (store, not mobile) unlocked already. But upon that koodo Sim it did reset... But will have a peek at the links provided too!
03-24-2020 07:08 PM
@Pawprints1986, it is always good to make a back-up of your phone, and especially your computer too! As you may know, on a computer, a hard drive can be corrupted, and one could lose everything (maybe, am just paranoid, and I learned from the past, but my hard drive died on me and lost eeeck, my wedding photos!) Wedding photos....holy crap....but, I made a back-up. Not on one external hard drive, but several hard drives. I have now backed up to the cloud too.
I had an issue with my Whatsapp, so, I backed up WhatsApp junk to Google. De-install it and re-install it and everything was back to normal.
From time to time, it's a good habit of backing up your phone content. I know the iPhone does it automatically when I plug in my wife's phone into the computer to charge up.
Lucky for me, when I made the switch to Public Mobile, I bought myself a new phone as a self-reward and had a new phone. But since you are using an existing phone, it should be fine. If in doubt, do a back-up and then start from scratch with a factory reset. Hence, fewer issues quite possible.
03-24-2020 06:59 PM
@kselmak wrote:Hope this helps
See 2 posts above yours...... 😉
03-24-2020 06:58 PM
@Pawprints1986 wrote:When I make the switch, can I expect that my device will do an automatic hard factory reset again, like it did when I first put my koodo sim in. Just need to know if I should back up all my data before switching sims ?
Well, while that would be a good idea anyway, just for a safety net, I shouldn't THINK it'd be necessary, especially after reading the link that @JoyLuck provided. While my current phone(Galaxy S3) is a fair bit older than yours, it was locked to Koodo when I got it, at which point I unlocked it, and inserted my Lucky SIM, and it didn't do a factory reset automatically.
03-24-2020 06:55 PM - edited 04-11-2020 05:38 PM
Hope this helps
It looks like later model are affected
But I'll be honest it's a good thing to back it up from time to time, just had a family member pay $100 to fix USB port on a piece of junk tablet just to get her stuff back (if she told us we could have maybe done something else) $30 more and she could have had brand new umidigi a5pro
Welcome to public mobile
03-24-2020 06:51 PM
@Pawprints1986 I had an s7 when I first switched to public mobile and mine did not do a factory reset and I came from Eastlink. I just shut down the phone, changed the Sim card and when powered up it started working. I believe I had to do some kind of little update that it prompted me to do but everything worked fine right away!
03-24-2020 06:33 PM
Have a look at this Samsung site:
Galaxy Smartphone - Factory data reset when inserting a new SIM card into your device
03-24-2020 06:31 PM - edited 03-24-2020 08:41 PM
@Pawprints1986 if you backup your data to a Google account it makes it easier to switch. You backup before inserting the PM SIM, the factory reset occurs and log back in when its done to restores your contacts etc. But I would try it first without the factory reset. Just switch your SIMS and restart your phone.
