02-12-2020 07:37 PM - edited 01-05-2022 09:28 AM
Hi, I was just checking at the Public Mobile's Phone compatibility website and for Samsung, it lists Galaxy XCover, XCover2 and XCover3 only. My phone is XCover4 and I have been using it with Rogers and even Freedom Mobile's SIM card did work. Will it work with Public Mobile, I would think it would but the website does not list it. Thanks
02-12-2020 10:41 PM - edited 02-12-2020 10:43 PM
@dwdrajesh wrote:my model is SM-G390W. I checked the Samsung website says it supports 3G UMTS (B1(2100), B2(1900), B4(AWS), B5(850)) and 4G FDD LTEB1(2100), B2(1900), B3(1800), B4(AWS), B5(850), B7(2600), B12(700), B13(700), B17(700), B20(800), B29(700), B66(AWS-3).
Does this mean it will work with Data on public Mobile's 3G and 4G both
As from earlier, the G390W is a Canadian-only version and is the same as was sold by Telus a couple of years ago. It does have a full range of both 3g and LTE frequencies compatible with Public Mobile. However, I do believe that LTE speeds are limited to category 3 (150Mbps), although that's not going to matter for Public Mobile's current talk/text/data plans.
02-12-2020 09:10 PM
@dwdrajesh , as @computergeek541 says above, yes this sub model will be fully compatible with PM.
Does this mean it will work with Data on public Mobile's 3G and 4G both?
02-12-2020 09:08 PM
02-12-2020 08:06 PM - edited 02-12-2020 08:07 PM
@dwdrajesh wrote:Hi, I was just checking at the Public Mobile's Phone compatibility website and for Samsung, it lists Galaxy XCover, XCover2 and XCover3 only. My phone is XCover4 and I have been using it with Rogers and even Freedom Mobile's SIM card did work. Will it work with Public Mobile, I would think it would but the website does not list it. Thanks
The Samsung Xcover4 absolutely does work at Public Mobile. In fact, Telus actually sold this model.
Be careful which variant you get. The G390W is the variant that you want as it not only supports both HSPA bands used at Telus/Public, but also supports a good range of the LTE bands used. The G930W is also the same version that Telus sold. This model will also work on the 3g/HSPA networks of both Freedom and Videotron If you're wondering, I know for a fact that Frequency Check got the UMTS specs wrong for this version: it does work on Freedom 3g. The G390W was only officialy sold in the Canadian market.
The G390F will also work at Public Mobile.. This variant also supports both UMTS bands 2 and 5
It's really the G390Y that you don't want to get because of lmited LTE bands. However, based ont he informatoin that I see, even this will sill work at Public Mobile on the 3g bands.
02-12-2020 08:03 PM
@dwdrajesh what's the sub model?
02-12-2020 07:54 PM - edited 02-12-2020 08:08 PM
According to
https://www.samsung.com/ca/smartphones/galaxy-xcover4-g390/
It is compatible both 3g and LTE matches Telus
I guess there are different versions of it
You can figure out the version if you go to settings/about this phone
Warning though your phone may be unlicked it may have locked itself to the first provider. Good news is that Samsung and Rogers both must give you the unlock key free of charge.
Another thing is that I have heard of Samsung phones doing the reset when changing the sim without any warning, do please make sure you backup everything you have on it before switching sims
02-12-2020 07:43 PM - edited 02-12-2020 07:48 PM
@dwdrajesh according to Gishan.net there in 4g LTE coverage. So no, sorry. Basically you can talk and text, but your data would depend only on 3g coverage. So, where there isn't any, you won't have any data.
