10-29-2016 01:37 PM - edited 01-04-2022 01:05 PM
I just signed up, and my phone says 3G on the top right.
Is my Samsung Galaxy S4 compatible with LTE, or just 3G?
Thanks!
10-29-2016 07:15 PM
@jheili99 wrote:also keep in mind the following:
4G is actually LTE .... they are both about the same .... if you are in a very good location as i am, then you might even be able to receive LTE+ ( which is advanced LTE/4G ) .....
Samsungs are a bit weird I've found. between the different types of networks that could be considered 4g I've seen it say: 4g, H, H+, LTE, or 4g LTE (and maybe LTE+ as you said)
10-29-2016 04:30 PM
Hi @ang, I believe @computergeek541's reply is probably key here--what is your specific sub-model of S4? e.g. SGH-i337, I9505G, etc.
10-29-2016 04:06 PM
There are many different variations of the Galaxy S4. What's your exact model number and did you buy it from a carrier? If it's one from Wind, it will definitely not work on Public's LTE.
10-29-2016 02:55 PM
10-29-2016 02:44 PM
Hi @ang!
You can go to willmyphonework.net and enter your S4's model number and check if its compatible with PM's LTE bands.
10-29-2016 01:41 PM
hi..
yes it is :
also check you APN settings and make sure they are set to PM network
