03-25-2019 01:45 PM - edited 01-05-2022 03:56 AM
Hi,
I was going to buy a Samsung Galaxy J4 Unlocked 4G LTE Smartphone for 150.00 US in Michiagn.
Public Mobile site says both IM # "should work on Public Mobile"
The phone is unlocked the salesman said it will work anywhere in the world on LTE Network.
The carriers listed are AT & T GSM
and T Mobile GSM
Any advise about this phone being a 4G 4G LTE working on Publics system?
01-31-2020 08:42 AM
Sim cards all come with knock out templates that are disposed of when installed in the phone. If you go to any mobile phone outlet ask them for the discarded template that will allow for sizing to your phones Public mobile Sim. It does not need to be a Public mobile outlet, all mobile phones use the same templates.
01-31-2020 03:18 AM
That's great news - it doesn't have the correct size slot for my sim, but I'll go to the kiosk and try it out. I dropped my old phone and it's cracked.
01-30-2020 07:44 PM
Yes it will work fine provided it is unlocked.
01-27-2020 11:34 PM
@april26 wrote:I have a Samsung J4 SM-J400F - J4 it's not listed on the sites mentioned. Do anyone know if it will work?
The Samsung site suggests it might get some connection but not all. It might be a bit light for this place.
Try any non-Rogers (to be sure) SIM and see if it connects fine and does calls/text/data.
01-27-2020 11:24 PM
03-25-2019 02:53 PM
@Patrick_R AT&T and T-Mo support are good signs.
Checking the spec sheet on GSM Arena ( https://www.gsmarena.com/samsung_galaxy_j4_core-9397.php ), I would say the SM-J410G/DS version has better LTE support than the SM-J410F/DS version, but either will work fine for calls, texts, and HSPA+ data. Either will work for LTE in coverage in areas with band 5 or 7 coverage, but the SM-J410F/DS also offeres the "core" band 4 as well as bands 2, 12, 13, and 17 all of which are helpful too. More info here: https://productioncommunity.publicmobile.ca/t5/Discussions/LTE-network-fundamentals/m-p/134356#M5822...
03-25-2019 02:06 PM - last edited on 03-25-2019 02:10 PM by computergeek541
Funny not sure what is missing both IMEI # are
Edited by computergeek541 for privacy reasons.
03-25-2019 02:00 PM
@Patrick_R wrote:Funny under will my device work it lists all Samsung J phone but the J4
Interesting, chek to see what it is missing compared to what PM requires.
03-25-2019 01:53 PM
03-25-2019 01:46 PM
@Patrick_R wrote:Hi,
and T Mobile GSM
check your phone here.
