05-10-2018 09:40 AM - edited 01-04-2022 04:15 PM
I have an unlocked Samsung Galaxy Ace 2 that worked on the chatr network but doesn't find the PM network. I have a basic voice only SIM. When I do network search it only finds the Rogers network. I checked the hidden menues and it shows as unlocked for sure. Has anyone else had issue with some phones not supported by PM?
Thanks
05-10-2018 04:39 PM
@ynvisram wrote:From this site:
PM does support GSM 850 and 1900 PCS bands. Is this correct?
Unfortunately, that is not correct. That site has long been listing that exact same mistake. Public Mobile has never had a 2G GSM network. For a phone to compatible with Public Mobile's voice services, your phone must have 850/1900MHz UMTS compatibility (bands 2, 5).
05-10-2018 09:49 AM
Please, use this site to check for phone compatibility with Public Mobile.
05-10-2018 09:47 AM
From this site:
05-10-2018 09:43 AM
This is GSM phone and will not work with Public Mobile!
