12-10-2025
06:38 PM
12-10-2025
06:56 PM
computergeek541
01-29-2026 11:21 AM
Still?
I use them all the time no problems. I won a McDonald's gift card the other day.
I have Android phone so I asked Google 'why are my sms to radio stations failing'?
It have me a brilliant answer. Check it out on your phone.
I checked my settings and it says Always ask. I usually do that for most of my apps.
Try it let me know if it works!!!
01-29-2026 10:22 AM
It says "failed" when I send in - to any radio station. No prob sending msgs to contacts
12-10-2025 11:17 PM - edited 12-10-2025 11:18 PM
@hTideGnow wrote:hi @AMJ108
what exactly meant by not going through to "radio stations"?
SMS messages to shortcodes are often used for promotions/giveaways.
12-10-2025 07:08 PM
As long as the phone number is valid, the sms should work.
Does other sms to friends and family work? How do you know that it doesn't work? Is this to 1 station or many different stations?
12-10-2025 07:06 PM
