08-05-2021 01:54 PM - edited 01-06-2022 03:02 AM
I have had an account for some time. Recently I bought a refurbished phone from Public. I thought, wrongly as it turns out, I could just change the old SIM for the new one in my account and it would connect with the new phone. Now I'm stuck. Neither phone is working and it won't accept the new or old number to change back. HELP! The new SIM, which came with the phone, works in the old phone. How do I get the new one to work?
Joining Public
08-05-2021 02:53 PM
@LyndaW1 : So is the new SIM working on the new phone now?
08-05-2021 02:53 PM
Have submitted a ticket. Thanks for the help and the sympathy. I was slowly losing my mind here!
08-05-2021 02:24 PM - edited 08-05-2021 02:25 PM
@LyndaW1 : Oh good. Glad for some progress. I would still contact the CSA's and switch it all around to allow you to have a new unused SIM. But that's up to you.
Edit: Can you go into the settings and find which network it's connecting to or set it to auto and then set network mode to things like LTE, 3G etc.
08-05-2021 02:23 PM
I put the new SIM in the old phone and that works. I don't understand why, when I put it in the new phone it doesn't work.
08-05-2021 02:22 PM
I'd gone in and changed the SIM number before I put it in the new phone. The old SIM has been deactivated but the new one doesn't work in the new phone. Messing around now and getting somewhere. I hope.
08-05-2021 02:20 PM
@LyndaW1 : But nor does it say that if you're an existing customer to just move the original SIM over and keep the new SIM on hand.
So you fully shut down the phone, inserted one of the SIM's and no service? The same with the other SIM?
08-05-2021 02:17 PM
Thanks Jade. No where does it tell you how to connect if you have an account already. Just too eager to get new customers apparently!
08-05-2021 02:02 PM - edited 08-05-2021 02:04 PM
you can put it the old SIM card is still Activate one and is will be working
but if you want to change from old SIM to new SIM ?
08-05-2021 02:01 PM - edited 08-05-2021 02:05 PM
All you need to do is to put the old SIM in the new phone.
But if you activated the new SIM, you need you log into your Self Serve account and click on My Plan>My Usage>change SIM card.
08-05-2021 02:00 PM
@LyndaW1 : Oh dear. You didn't need to use that new SIM. You could have just moved the old one over to the new phone.
You will need to contact the moderators. Ask them to re-instate the old SIM onto your account and to clear any connection to the new SIM to let you use it elsewhere or for a referral.
@J_PM : Perhaps it would be more helpful for the CPO buyers and the SIM provided to indicate somewhere that they don't need to use the new SIM.
