06-24-2025 09:44 PM
I suddenly saw a sim failure message and lost my network connection. I tried updating iOS, restarting and removing/re-inserting the sim. No luck. What can I do to fix this?
06-24-2025 09:58 PM
I tried swapping. Both worked! Then I swapped back, both still working! 😅
thanks!
06-24-2025 09:46 PM
did you try your sim on another phone? test that first
and try using another sim card, active one, on your iPhone
