09-17-2022 04:11 PM
Unable to change my sim number on my account. I apply the new number and press save changes and the new number changes to all zeros.
09-17-2022 04:50 PM
To verify that it is usable.....try the first step of activation. Once all numbers are entered you should get a green check mark but if you get a red exclamation mark...it is an issue.....likely already used.
09-17-2022 04:13 PM
@Gg3 Hi clear your cache and cookies or try a different browser in private or incognito mode reboot your device and try again
