SIM card iOS to android
Stinson
my son uses iPhone and will be getting a Samsung phone for Xmas. Will we be able to just put the SIM card from iOS into the new android phone?
2 REPLIES 2
Stinson
Thanks
HI @Stinson
yes he can. The SAME sim card can be used on both iOS and Android. So, just switch the sim card over and it will work
of course, he would need to install Samsung "Smart Switch"  to transfer his phone data from iPhone onto the Samsung phone
https://www.samsung.com/uk/support/mobile-devices/how-to-transfer-data-from-an-iphone-or-ipad-to-a-n...
