06-08-2023 02:42 PM
It says invalid SIM / SOS only
It was working fine before
when I reboot the iPhone it works then same message again
06-08-2023 03:51 PM
@softech I have switched the SIM cards on my 2 iPhones. Looks okay for now I guess I have to wait and see.
I tried the link and no it is not blacklisted or reported as lost or stolen.
thanks
06-08-2023 02:46 PM
@TimAz sim cards usually do not fail easily
please reseat the sim card. Power down the phone, take sim card out for minute. Then put it back and power up
if it does not help, try the sim card in another phone
Also, check if your phone is blacklisted just in case
https://www.devicecheck.ca/check-status-device-canada/
