SIM Card
cunlifmd
Hi I am trying to sign up with my new SIM card I just got in the mail and it says the number in iInvalid. Can somone please advise why this is happening this is a brand new card?
2 REPLIES 2
cunlifmd
Thanks incognito mode worked
mimmo
did you start the process and then  cancel? or has it always said invalid sim number.
if the first you might need to wait an hour or so.  if the second, try incognito mode and make sure you type all the numbers corresctly.
