SIM Card Not Suppoted
100mileknight
I have an unlocked iPhone 4S that I want to use with PublicMobile. Bought a PublicMobile SIM card and put it in but got "SIM Not Supported". My old SIM card still works, I checked that the phone is unlocked and I have restored my iPhone through iTunes and still get the same error.
How do I fix this???????
cavemantoronto
After old carrier tells you it is unlocked, back up your data and do factory restore. This is needed on old iPhone for unlock to be effective.  It will tell you in iTunes phone is unlocked after that.
chukdefatey
That message means that the phone you think is unlocked is not.
geopublic
@100mileknight Others in the past have mentioned that they had to access itunes twice with the PM sim in the phone before it worked.
ChuckYeah
Unlocking is now free so the first call i would make is to your old carrier just in case. There have been situations where putting in another carriers sim has locked the phone to their service. Regardless, it seems like the most logical first step.
Your phone isn't unlocked if you are seeing that message. You'll need to have it unlocked before you can use it at Public Mobile.  The original carrier (if it's a Canadian carrier) should be able to help.
