SIM Card Delivery - Incomplete
pavan7314
Hello,
I have not yet received the delivery of my SIM card as it has been more than 8 days now.
Regards
User
8 REPLIES 8
@tehowennathe wrote:
When a friend of mine ordered their sim card it took them a week and a half to get it. These days most places you order from seem to take slightly longer. Don't worry just yet. Give it more time the contact a moderator. Could be on it way and just remember more people these days are ordering online.
Only slightly longer will take some luck. Often, these delays will only be a few days. However, I've had instances of sending outgoing packages within the same province that took almost a month to be delivered. I also received something recently that took 4 months to arrive.
tehowennathe
tabi159w
Wait a few more days and then email [email protected].
kselmak
Since March it's normal that out takes 2 weeks.
Can you track it?
@pavan7314 try usimg your PM shipping email order number to track your SIM card.  Some of them have a tracking number. SIM card shipments have been averaging 3 weeks to get there. Use @gpixel 's suggestion to wait before contacting the moderators.  Stay safe.
Hi @pavan7314 (User 🙂 ),
I remember it took mine just over one week. Remember there was also some holidays last week, it could have put back some deliveries.
But yes, if you do not have the tracking to look up and you want to check up on it, like @popping said, maybe send a message to the moderators:
Hopefully, it arrives soon!
Remember to make sure to use a referral code during the activation process to receive $10 off on your 2nd month’s bill.
gpixel
@pavan7314 try waiting till Friday and if you still haven't received it, contact moderators. covid is still causing delays...
popping
@pavan7314
Send a private message to moderator to find out what happened to your SIM card.
